Question Denon avr-x1200w Spotify help please
Discussion in 'AV Receivers & Amplifiers' started by N3ptun3m00n, Apr 9, 2016.
  1. N3ptun3m00n
    N3ptun3m00n
    Jul 6, 2011
    2,854
    Lincolnshire
    +350
    Hi all
    I seem to be struggling to find the reason that when I try to switch my amp on remotely with Spotify connect no sound comes out unless I have the TV on, one it's on and the sound starts I can switch the RV off again and it's fine.
    It's got to be something to do with ARC but I can't work out what setting be it on the TV or another that I need to change.
    Can anyone help??
  2. N3ptun3m00n
    N3ptun3m00n
    Jul 6, 2011
    2,854
    Lincolnshire
    +350
    Reset the denon. Reset the TV. Neither worked. Switched the power off for half an hour and sorted if!!!
