Denon AVR X1200w or Denon AVR X4400H
Discussion in 'AV Receivers & Amplifiers' started by joner7777, May 16, 2018.
  1. joner7777
    joner7777
    Dec 11, 2015
    424
    uk
    +421
    I have a x1200w and I like to fiddle about so --
    Will there be much difference between the x1200 and the x4400 in quality of sound?
    I do find with mine that it really depends on where the feed comes from Ie, youtube or Spotify or Xbox one.
    I rarely turn up to the max.
    The x 4400 H appears on eBay sometimes but will i find much difference?
  2. gibbsy
    gibbsy
    May 17, 2007
    10,307
    3
    Cwm Cynon, De Cymru
    +5,308
    The 4400 is four tiers above the 1200 so the simple answer is yes. Everything about it is better. Better amps, better EQ, better connectivity. However it may be a waste of money if your speakers are not up to the task.
  3. joner7777
    joner7777
    Dec 11, 2015
    424
    uk
    +421
    I see, I have kef cinema reference series 1999 which was the most expensive at the time.
    Still working fine.....but can speakers get better ?
  4. gibbsy
    gibbsy
    May 17, 2007
    10,307
    3
    Cwm Cynon, De Cymru
    +5,308
    I remember your build now. Are they the same speakers that are in the photos? If so they would definitely sound better with the 4400.
