Spawncalibur
I just got the DENON AVR-S920W but the video & audio won't work right for my PC even though I have no issues with my older Yamaha & Onkyo receivers. I get no audio options and few resolution options. I tried my on-board motherboard HDMI but the results were the same. I have a GTX 1050 ti and tried many times to do clean re-installs of the Nvidia drivers with Display Driver Uninstaller, as well as unplugging cables for a while and trying different cables & ports. I tried my older PC with a GTX 650 but again no audio or all resolution options.
I have added screenshots of my Nvidia Control Panel & Management. As you can see it says "Corrector: DVI - PC Display", however I'm using HDMI so thats odd. Only a few resolutions options, no 1080 or 2160 for my HDTV. On digital audio it lists everything as "no audio capable display available". In Management it lists my monitor as "Generic Non-PnP Monitor", I'm using a HDTV which is a 4K Haier 48UF2500.
I don't know what to do, I'd appreciate any help. Thanks
[edit]- I connected to a PC monitor and it worked fine. So I'm confused why the audio receiver won't work through to that HDTV. My work around is to have two separate connections where one HMDI goes to my HDTV and my DVI to my audio receiver, which oddly would only work if I unplugged the HDMI output from my TV, otherwise it wouldn't work.
