Hello everyone, I have a denon avr-s760h that was purchased new about 4 months ago. The volume is driving us crazy. When you adjust the volume (up or down) it will increase several numbers. If it's on 40 and you want to turn it down and just tap the volume down button it will go to 15 in a split second. It doesn't matter if you are using the Denon remote, the tv remote or the cable box remote. If you click it one click at a time it decreases .5 or increases .5 each time. So the only solution so far is using the Denon App for volume control. Any ideas from anyone. It's to the point we are going to replace it with something else. Thanks
