Question Denon AVR S710W HDMI Audio
Discussion in 'AV Receivers & Amplifiers' started by Toastjam, Jan 2, 2017.
  1. Toastjam
    Toastjam
    Jan 2, 2017
    4
    Charlotte, NC, United States
    It seems the S710W audio is either sent to the AVR connected speakers or through the HDMI cable to the monitor. I'd like to be able to use both the speakers connected to the receiver as well as audio from the TV connected via the HDMI cable. My previous Yamaha receiver gave me that option. My situation is I have a second TV hooked up in a separate room connected to HDMI splitter off the back of the receiver (the HDMI signal is split to the main TV in the room with the receiver and a second TV as I mentioned). If I have a movie playing in the main room through the speakers connected to the S710W I only get video to both connected TVs so we can't hear the movie in the second room. Hope this makes sense. As I mentioned it wasn't a problem with the Yamaha so I'm assuming I'm probably missing a simple solution.
