Denon AVR-7200W No sub output playing audio??
Braddersmd
Established Member
Hi All,
In the final stages of setting up my new cinema gear, and I'm having trouble getting the amp to play ball when playing a stereo audio input.
I have a system that uses Artcoustic speakers, and there is very little bass (if any) from the speakers when they are used for a stereo audio source. For any other input type (AV from Sky, Oppo BluRay etc), the subs are automatically selected by the amp, and play accordingly.
When the input is from Sonos, the amp senses only a stereo input and pushes output to the L & R speakers only - without including the subs. I've searched the manual, and menu options, and unless I am going blind cannot find a way to link the subs to the L & R for this purpose.
Can anyone help? Do you know if it's possible? If not, I may need another amp solution.
Cheers, Bradders.
paulst10
Are your speakers set to small?
dante01
Unless you manually set your speakers as being SMALL from within the speaker configuration then the sub would only ever be utilised in conjunction with audio that includes a discrete LFE channel. Stereo two channel audio doesn't include an LFE channel so you'd need to redirect lower frequencies away from your main speakers to the sub using a crossover filter setting on the receiver. The crossover redirects frequencies at and below the setting away from speakers designated SMALL and send them to the sub. It is generally suggested you configure all your speakers as being SMALL irrespective of their physical sze and use a crossover appropriate for their capabilities. This means setting the crossover at least 10Hz higher than the lowest rated frequency handling ability of the speaker or speakers in question.
You may find this Audyssey article informative:
Small vs. Large
Do you have a subwoofer in your system? Great. Then your speakers are small. Before you get all upset, read on. This is one of those audio myths whose time has come to be busted. To understand why, we need to talk about Bass Management.
In the early days of home theater it was thought that in order to reproduce the full movie surround experience at home it was necessary to place 5 large loudspeakers in the room. The reason for the size was the woofers. To play at theatrical reference levels and reproduce the deepest bass available in the content requires each speaker to have 12” or larger woofers. Let’s just say that this theory didn’t get very far in the real world.
A better and more practical approach came after studying human perception. The mechanisms that we use to determine the direction of arrival of sound depend on the frequency. At high frequencies the wavelength of sound is small and so sound coming from the side is shadowed by our head. That creates a level difference between the sound reaching the ear closest to the source and the ear on the other side. Our brain analyzes these level differences and produces an estimate of where the sound is coming from. But at lower frequencies, the wavelength of sound gets longer and our head is not large enough to produce a level difference at the two ears. Instead, we analyze the difference in time of arrival of sound at the two ears. Sound arrives first at the closest ear and we use that to determine the direction. But even that ability fails us below about 80 Hz. The wavelengths get very large and it was found in listening tests that 80 Hz is the frequency below which most people can not localize the direction of sound.
Taking advantage of this apparent “deficiency” in our hearing was what made home theater practical for millions of homes. Five satellite speakers of reasonable size could now be used because they no longer required large woofers. A subwoofer (or two) can reproduce the lower octaves and it can be placed out of sight since its content is not directional.
But there is also a practical advantage: directing the bass to a dedicated subwoofer channel with its own amplifier greatly improves the headroom in the main channels. The idea behind this was proposed in a Society of Motion Picture Engineers (SMPTE) meeting in 1987. The participants could not agree on the minimum number of channels required for surround sound on film. Various numbers were being shouted out until a voice was heard from the back: “We need 5.1”. Everyone’s head turned around to look at Tom Holman. He proceeded to explain what he meant: Take the low frequency content from all 5 channels and redirect it away from the satellite speakers to the subwoofer. If we do the math, then the content below 80 Hz is 0.004 of the audible 20,000 Hz bandwidth. But 5.004 didn’t sound as catchy so Tom rounded up to 5.1. By the way, don’t make the amateur mistake of calling it 5 dot 1. It is a decimal: 5 point 1.
Fast forward to the early 90s when the first DSP powered home theater receivers started to appear. Along with progress came complexity. Some industry forces believed that Bass Management should be an option that could be turned on and off by the consumer. That’s not necessarily a bad idea, but to make an informed decision requires much more knowledge about the system than what was available to the typical consumer. So, the Large and Small rule of thumb was established. The idea was to look at the size of your speakers and decide whether their woofers were “large enough” to reproduce the lowest octaves at the required levels. It was a noble thought, but looking at it 15 years later I believe that it has led to nothing but massive confusion. The poor consumer was led to believe that Large is somehow a good thing and was then left wondering why there was nothing coming out of their subwoofer.
Redirecting the bass to the subwoofer relieves the receiver amplifiers from having to work on reproducing the low frequencies and this greatly improves the headroom. If you happen to be using Audyssey MultEQ for room correction, you will achieve much better low frequency performance because the MultEQ subwoofer filters have 8x higher resolution than the filters in the other channels.
Here is a better rule: All speakers are Small. In today’s complicated AVR lingo that just means: If you have a subwoofer you should always turn bass management on. Always. Even if your receiver clings to the past and automatically sets your speakers to Large.
Small vs. Large | Audyssey
jackal385
Established Member
When I ran setup on my 7200 it specified my b&w 485 s2 and centre speaker as large. Should I go against the amps recommendations and still specify them as small ?
dante01
Audyssey aren't responsible for the speaker sizes or the crossover determined by the calibration. Audyssey do measure the roll off point for speakers, but it is the receiver manufacturer who use this measurement to determine speaker sizes and where to set the crossover for them. Audyssey themselves suggest you override this irrespective of the physucal size of speakers and set the speakers as being SMALL manually after the calibration is complete.
Again and as posted above, you may find this Audyssey article of interest:
Small vs. Large
dante01
You cannot set them as being SMALL in the absence of a subwoofer. The only option available for the front speakers if there's no sub is LARGE. You can set the other speakers as being SMALL without a sub and that makes it so that frequencies at and below their associated crossovers are redirected to the front speakers. If playing back stereo content in stereo without a sub then you are given no other option than to send all frequencies to the front speakers and the front speakers size setting is greyed out in the absence of a sub.
PSug
Thank God for you guys! Excellent explanation. I think Denon should include something like that in the 287 page manual.
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
