Denon AVR-5805
Discussion in 'AV Receivers & Amplifiers' started by Bacus, Mar 24, 2006.
Tags:
  1. Bacus
    Bacus
    Dec 30, 2004
    8,980
    Close to the sea
    +2,920
    Hi, just wanted to know if anyone has got this amp and if it is any good ? Doew it upconvert all input signals to HD output ?
  2. Bacus
    Bacus
    Dec 30, 2004
    8,980
    Close to the sea
    +2,920
  3. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    It's the A1XV over here. Due to be updated to the A1XVA model next month. The current model will upconvert Composite, S-Video and output them via Component. It will upscale the signals if you wish and you can choose the output resolution (480i/576i, 480p/576p, 720p and 1080i). Just bear in mind some copy protected discs won't be upscaled even if you select a higher resolution. The updated model will also get analog to HDMI upconversion and scaling.
    And yeah, it's a good amp. :)
  4. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,671
    You may also get a few more replies in the appropriate section of the forums,for integrated amps/receivers...moving your thread there.
