I am about to replace my Onkyo 504 to something which should keep me going for a while.
At the same time I would like to avoid the obvious trap to buy the biggest box just to be sure I haven't missed out anything. Looking at the impressive feature list of the 4310 reveals:
Audyssey DSX - not needed
HDCS decoder - no idea what this will really do for me?
D/A converter in differential scheme - Can I tell the difference?
A/D converter 192kHz - More is better but...
Ipod dock - I use Creative Zen
Denon Link 4th. - What is the impact on the jitter control?
2nd HDMI - not needed
However, 2.9 kg of extra weight might indicate a stronger power supply resulting in more "punch".
So what is the honest recommendation other than "if you can afford it go bigger"?
Your feedback is greatly appreciated
Sunzi
Sunzi
