Denon AVR 3805
Discussion in 'AV Receivers & Amplifiers' started by GliderRider, Sep 6, 2005.
Tags:
  1. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    Why do my Bose headphones sound better on my iPod than on my 3805. What options do I have to adjust the sound?
    The same is also true when I listen to Stereo through my KEF Q7's, I need to use the sub to get decent base, but this sometimes sounds too boomy.
    My ancient JVC Amp and Celestion UL8 Speakers deliver a solid sound, granted this is with some EQ adjustment.
    Watching DVD in DD 5.1, the sound is awsome, no complaints there.
    Am I missing something.
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,820
    The purest sound would be to use the Pure Direct mode and you can also defeat the sub output in this mode if you wish. You also have the option of using the EQ with this mode but it has to be enabled in the setup menu's (Direct Mode Setup).
    For Stereo Mode you can also adjust the bass and treble if you wish. This isn't available on the Direct/Pure Direct modes.
    You can also tinker with the manual EQ as well but this is a basic equalizer and not parametric like the Auto EQ system.
  3. GliderRider
    GliderRider
    Dec 17, 2004
    119
    16
    London, Middlesex
    :) Thanks Jase, didn't know you could do this. (The manual is not great). I'll try this tonight.
