Denon AVR 3805
Discussion in 'AV Receivers & Amplifiers' started by humjoh, May 2, 2005.
Tags:
  1. humjoh
    humjoh
    Does anyone know how I configure my AVR-3805 to decode SACD's ??
    It looks like a software update is required to route DVD-A & SACD thro'
    the D-link from my DVD-3910. DVD-A works fine.
  2. juniper
    juniper
    Dec 30, 2003
    1,875
    48
    +60
    For the time being (not sure how long that'll be.......maybe someone else can help), you'll need to use six analogue inputs for SACD. With auto configuration the 3805 will switch itself between sources.
  3. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    You should also need this for DVD-Audio because the 3805 has no inbuilt decoding for DVD-Audio as far as I'm aware.
    If it's working via a digital connection I think you're probably listening to the Dolby Digital track and not the DVD-A track??
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    To the best of my knowledge, there are no amps/receivers which decode SACD's or DVD-A's - the decoding is always done in the DVD player and passed through 6 analogue cables to the amp/receiver for amplification.
    Cheers,
    Martin.
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    The 3805 can take a digital DVD Audio signal via Denon Link. All decoding, bass management etc is then done by the 3805. Denon Link can also pass PCM, Dolby Digital and DTS. The only thing it cannot pass is SACD because permission has not been given by Sony/Philips.
    SACD can be passed digitally via I-Link (Firewire). Some Pioneer's have this, as will newer models from Yamaha, Denon.......... :thumbsup:
  6. mjcairney
    mjcairney
    Oct 26, 2003
    7,135
    2
    2
    137
    Airdrie, Scotland
    +986
    Jase, I stand corrected, as far as DVD-A is concerned anyway.
    Cheers,
    Martin.
