Denon AVR-3803 views?
Discussion in 'AV Receivers & Amplifiers' started by deightonp, Mar 8, 2003.
Tags:
  1. deightonp
    deightonp
    Just purchased a Denon AVR-3803, along with Panny 5 42" and Kef 2005 speaker package, they all arrive next wednesday.
    I was wondering if anyone has purchased the 3803 and what their initial reaction was? Any feedback would be gratefully received.
    Thanks,
    Paul.
  2. nathan_silly
    nathan_silly
    What, you haven't seen or heard them going?
  3. deightonp
    deightonp
    Nathan,
    Yes I have demo'd it, but how it sounds "in store" is possably a little different to how it will be in my house. Also I have not owned an AV Amp before so I do not have a great deal of experience, other than the comparisons I made, again in the stores, before deciding on the Denon.
    I was merely wondering what peoples first impressions have been, particularly as it is a new product.
    Cheers.
  4. nathan_silly
    nathan_silly
    No problem. Here's some tips..
    Set the speakers to small. Play some music for about 8 hours straight at lowish volume, that should burn in the amp, speakers and subwoofer.
  5. DJP
    DJP
    Jan 10, 2003
    72
    Hampshire, UK
    +5
    deightonp - I'm sure that you will be very happy with the 3803. You will find the audio delay fature very useful, especially if you are viewing Sky material.
    The manual is a rather weighty tome but that's largely due to it's multi-language nature.
    I found that mine sounded a bit bright until after it had run in a few hours but your mileage may vary. Now that I've had it for a couple of weeks it is an improvement on the 3801 I had before and I really like it's sound.
    Seems like you are going to have a very busy Wednesday setting it all up. :) The first time I set up my 3801 it took around 3 hours to get all the cabling sorted, but that did include 9 new runs of speaker cable.
    One tip, if the speaker cables you use have banana plugs at the Amp end you can still use them. The inserts in the Denon speaker binding posts can be levered out with a jewelers screwdriver (or similar pointy implement). The only downside is that the little inserts tend to break while extracting which may be an issue in the unlikely event that you have to return the Amp.
    Derek
  6. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    i have similar setup.
    you wont be dissapointed.
    After reading many reports , users would comment that
    the kef sub isnt very good musically.
    well i disagree.
    the system sounds great both dvd's and music cd's (played via 2800).
    theres is masses of Bass.
    pink floyd sounds great.
    Enjoy.
    post your comments.
  7. BigH
    BigH
    Dec 26, 2002
    447
    Hampshire
    +8
    Hi Guys,
    I am considering the 3803 because of the delay feature. I have 50" panny plasma and Sky dig and ISACAN Ultra video processor with the usual lip synh probs. Can anyone tell me the maximum delay that the 3803 can achieve as the spec sheets don't say.
    Thanks.
    BigH
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
  9. keyser
    keyser
    Jul 23, 2000
    902
    gardabaer, Iceland
    The 3803 is reviews in the latest HCC mag.. has anyone read it??
