Denon AVR 3802?
Discussion in 'AV Receivers & Amplifiers' started by Paden, Oct 10, 2001.
Tags:
  1. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Hello all!
    Simple question, is this new receiver fan cooled?
    Cheers, Paul.
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    I believe so – not 100%. Why? Worried about the noise?
    Mark
  3. plb
    plb
    No it has no fan, but mine it does not seem to get too hot.
    Paul
  4. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Thanks for the replys. I've currently got a AVR 3300 which does have a fan & although hardly noticable..it is! I've got a 3802 on order & am v. excited, just wired my Sky+ box to my current receiver & things sound good already, with DPL2 things can only get better!
    Cheers, Paul.
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,519
    WEST MIDLANDS
    +1,425
    I`ve noticed it runs cool aswell, i had mine at very high volumes for a couple of hours and it was barely warm.
    Cheers Carl
  6. Tony.M.
    Tony.M.
    Hi guys,
    Talking of the cooling aspect of the 3802, I have downloaded the instruction manual whilst waiting before they came in stock.
    On digesting the endless pages the first few pages refer to the set up.
    On this Denon recommend that about 4" of space is required around the unit for cooling. Do you guys actually follow this rule, or have you hooked up your amps in hifi cabinets?
    I just wondered otherwise I might have to rearrange the furniture again. :D
  7. Duncan Harvey
    Duncan Harvey
    daft question - but do you have a url for the manual - might pass the time whilst I'm waiting for mine to arrive!
  8. CARLOS
    CARLOS
    Feb 11, 2001
    6,519
    WEST MIDLANDS
    +1,425
    Try here http://denon.jp/europe/avr3802.html
    Click on the PDF file
    Cheers Carlos
    P.S Where did you order it from in the end ?
  9. Tony.M.
    Tony.M.
    Hi guys,
    Thanks Carlos for putting on the URL, sorry I've not logged on the site until this morning, so I didn't see Duncans request.
    Any answers on the cooling front? I'm going to get my amp within the month now, and was hoping to place it in a cabinet just as my Kenwood KRV888 is at present.
    Any placement experiences greatly appreciated!!
    :D
  10. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Are you sure it has no fans? Both the A1SE and the A11SR have fans so I'd be surprised if the 3802 had none.
    Mark
  11. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Like I said I've currently got the 3300 & I did have problems with it overheating when I had less than the specified clearance. I increased the clearance as per the manual & had no further trouble.
    Cheers, Paul.
  12. CARLOS
    CARLOS
    Feb 11, 2001
    6,519
    WEST MIDLANDS
    +1,425
    I`ve just measured and the gap above mine is about 2 and a half inches as i said before i have run it at very high levels for a couple of hours and it was barely warm.
    so i don`t think overheating should be a problem.
    Cheers Carlos
  13. Tony.M.
    Tony.M.
    Thanks lads,
    The 3802 definately does not include a cooling fan at the rear of its heat sinks, I've seen enough detailed piccies including internals to confirm that much.
    I will try to gain as much space as possible around the amp, but it will be placed in a wife friendly furniture cabinet, which makes it awkward to make allowances for all the kit.
    Me thinks one of my cherished black boxes will have to be relegated to another position
    if I encounter overheating. We'll have to wait and see.
    Once I've got it installed, I'll let you guys know.
  14. N19
    N19
    Mar 9, 2001
    24
    UK
    Got one in a little room 3ft from my listening position. The only noise comes out of the loudspeakers. In stock at superfi.co.uk £629.
  15. Paden
    Paden
    Jul 27, 2000
    577
    +23
    Hello all!
    Going off at a bit of a tangent I know but is the standard warranty offered on this receiver 3 years?
    Cheers, Paul.
  16. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,508
    UK.
    +3,011
  17. plb
    plb
