Denon AVR 3802 Receiver problem
Discussion in 'AV Receivers & Amplifiers' started by MALC12, Feb 3, 2002.
Tags:
  1. MALC12
    MALC12
    Feb 3, 2002
    52
    Evesham Worcs
    I own a three month old Denon AVR3802 reciever.
    Since wednesday night when it decided to shut it self down while in use I have had a flashing red stand by light.
    This according to the instructions is the protection circuit and switching the reciever off and waiting a while should reset it.
    I have disconnected all speaker leads and input/output cables and reset the microprocessor (as per instructions) but still on switch on all I get is about 2 seconds of the display and then off it goes to leave the flashing standby light.
    I have left the reciever unplugged from the mains overnight,this doesnot help.
    Is there any one who has had a similar problem with Denon who can give me some information/help on my problem.
    Malcolm.
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,708
    Take it back to your dealer, who should send it back to Denon.
    You´ve tried all the options I would have suggested. Sounds like there could be an internal short somewhere??
    If its only a few months old, they should replace it with another under warranty.
