Denon AVR 3802 or ADV 700
Discussion in 'AV Receivers & Amplifiers' started by zippo4, Nov 9, 2001.
Tags:
  1. zippo4
    zippo4
    Oct 28, 2001
    Kent
    As a complete newbie I would appreciate any advice on these two. Aside from the price what is the better product and why?
    Paul
  2. simonrossi
    simonrossi
    Hi, I don't know about the other amp you're considering, and I'm no expert.
    However I just got the 3802 (gold looks much better than the black imho) from krish electronics in chiswick for £649!
    I think its fantastic. I have only owned yamaha amps before but I'm so pleased I whent for the denon. Fantastic value for money.
    Pro logic 2, DTS ES discrete, easy setup via on screen menu's and the sound is to die for. Plenty of power, I couldn't be happier.
    the only thing I don't like is the remote. Very cheap and tacky looking, and quite confusing, i think its trying to do too many things. However i also purchased a Marantz 5000i universal remote, and once I have it all programmed that will be a far more stylish substitute.
    Regards
    Simon
  3. DodgeTheViper
    DodgeTheViper
    Oct 23, 2001
    19,679
    Inbetween Upgrades !
    +8,109
    Hi ,
    What speakers are you running off the Denon 3802 ?
    Are you pleased with the sound etc ?
    I am just about to buy the amp also, before it runs out i think !
    Kev
  4. simonrossi
    simonrossi
    I'm running, quite unusually, my old faithful JBL 4410 studio monitors. Sound fantastic with the denon!
  5. camelpooh
    camelpooh
    I bought a Denon 3802 on Saturday from Krish for £649.
    I am very pleased with it. I think you cant go wrong for the price. I heard a Yamaha AX1 at a friends house recently and wasnt that impressed. The Denon sounds a lot better. The controller was a bit frustrating at first but now I've got used to it its not so bad.
    I am running it with Tannoy M series speakers and an REL sub. I have connected my other sub via the main out connections next to the sub output.
    Does anyone know is this a reasonable way of connecting two subs to the 3802 as it only has one subwoofer out ?:p
