Denon AVR-3802 and multiple inputs
Discussion in 'AV Receivers & Amplifiers' started by jalpert, Jul 15, 2003.
Tags:
  1. jalpert
    jalpert
    This may be a dumb question, but is it possible using a Denon AVR-3802 to listen to two audio inputs at the same time. For example, I have a software app on my computer running that I need to hear sound for, but I also want to listen to music from my cd player at the same time. Any help would be appreciated!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    You can use the multiple room feature for this.
    Set up your system for 5.1 as normal (can't have 6 or 7.1 though :rolleyes: ) and then connect a pair of speakers to the 3802 surround back outputs and set them up as multi room from the set up menu. Tell 3802 to play from CD and PC for other room.
    Or use the tape outs to feed a pair of PC speakers and set 3802 to output CD while 'recording' PC (this gives you the option of 7.1 :cool: )
    So it is possible, but as far as I know, not through the same speakers.
    Mark.
  3. polaco
    polaco
    Jan 21, 2002
    14
    Portugal
    Use the the 7.1 external input, connect the CD to the front left and right channels, and the PC to the, say, surround back left and right channels. You won't be able to use DPLII or similar on the music, though.
