Denon AVR 3801
Discussion in 'AV Receivers & Amplifiers' started by dgj, Jun 25, 2001.
Tags:
  1. dgj
    dgj
    I am looking at getting this amp. As well as a DVD player I also have a laser disc Pioneer CLD 925 with a RF demodulator via a Yamaha DDP-2 AC3 decoder into my existing amp, will I be able to connect the laser disc direct into the denon and get rid of the Yamaha DDP-2?
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Sorry, but I believe you will still need your demodulator.
  3. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    875
    46
    Maidstone, Kent
    +174
    You'll still need the demodulator if you want AC-3 sound. If your're happy with Pro-logic then ditch the demodulator and connect via an optical cable.
    Gavin
