Denon AVR-3801 and Speaker Impedance
Discussion in 'AV Receivers & Amplifiers' started by nickoff, Dec 6, 2000.
Tags:
  1. nickoff
    nickoff
    Would anyone know if the new 3801 can run
    4 ohm (100W) main speakers?
    I'm cannot get an e-mail message through to Denon for advice as I am computer illiterate!
    The Denon dealer I have spoken to said that
    4 ohm speakers will be fine (they originally sold them to me when I brought a Denon 2500 pro logic receiver a couple of years ago).
    Would anyone have any advice or can some helpful forum user get advice from Denon? I would very much appreciate it.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Even the manufacturer claims the amp/receiver can handle 6-8 Ohm only it should work with 4 Ohm speakers, given that a) you don't drive them too hard and b) they have a high sensitivity.
  3. simonsez
    simonsez
    I agree, Dennon uses high current amps in their equipment you should be fine. Just to be safe I might buy that extended "if I burn out my amp" warranty. Seriously though, the receiver should have a "clip" indicator light, when that comes on you are dirving the amps too hard. Also listen for the cooling fan....a good indication the that amp is working too hard.
  4. StuartBooth
    StuartBooth
    I own a Denon A10-SE partnered with 5 Dynaudio speakers (4ohm impedance). Here's a small snip of an email exchange I had with one of the chaps in Audio-T when I asked this same question. Hope he won't mind me quoting him!
    The issue of impedance although it pops up regularly is generally irrelevant particularly on amps with a lot of current delivery like the Denon. Japanese amps as well as more specialist British, Scandanavian etc. often have lots of current and easily drive speakers like Dynaudio's. A £150 Denon amp would drive them (although the sound may not be very nice !! ). The whole rating is based upon a fixed frequency, in a fixed environment. The truth is speakers change their characteristics with frequency anyway.
    99
    HTH,
    Stuart Booth
    Somewhere in Buckinghamshire, England, UK
