Denon AVR-3300 set-up problem
Discussion in 'AV Receivers & Amplifiers' started by syogusr, Jul 23, 2004.
Tags:
  1. syogusr
    syogusr
    :confused: I have had this Denon AVR-3300 for about a year, but just decided to "properly" set up the system, as I have just acquired the new Onkyo DV-CP 802 universal player (which by the way is a great machine). Going by the manual's instructions, I push the set-up botton, but the initial menu does not display anywhere (Denon or TV) What could I be doing wrong? What should display is the "System Setup Menu", but does not. HELP
  2. Arcangel
    Arcangel
    Make sure that the remote is set to AMP (as it can control multiple things). I'm assuming you have the Denon connected to your TV via the Monitor Out so you can see it's onscreen menu?
