DENON AVR 2805 or a YAMAHA DSP AX750SE
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Sep 14, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    O.K.
    After much deliberation and review reading (although there isn't a lot out there on these!) I've come down to two amps/receivers to choose from.
    Which one is the BEST:
    The DENON AVR 2805 or the YAMAHA DSP AX750SE??
    Is there any others I should look at before taking the plunge?
    Thanks in advance for your help.
    Cheers,
    Martin.
  2. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Anyone?
  3. Radiohead
    Radiohead
    Dec 24, 2001
    4,405
    Amazingstoke
    +440
    Can I suggest using the "search" function.
    This very question has been asked and answered more than once
  4. sharr72015
    sharr72015
    Aug 13, 2004
    10
    I had a demo of the Denon 2805 and Yamaha DSPAX750, I prefered the sound of the Denon and that is the one I ended up buying.
    This is personal preference, the only way to find out for sure is to demo them both.
    Steve
  5. pez
    pez
    May 1, 2004
    776
    Newport
    +27
    what hi fi preferred the Denon (saying it would give its bigger brother the 3805 a run for its money).
    so i bought the Denon.
    it rocks!
    and its bleedin good for music too.
    pez
