Bragelonne
Hello,
I've had a Denon AVR-2802 for some nine years now and before I consign it to the rubbish bin, I'd just like to check if this problem has manifested before and whether it's, categorically, terminal and, if not, whether the repair cost would be a large chunk of a newer model.
Anyway, there is no sound output now from any input. I've tried analog, digital and the ext-in multi-channel audio.
The problem started when the digital indicator on the main display would flash for a while then resolve itself. This degenerated into no digital indicator and no sound from any of the inputs.
I've tried the microprocessor reset from the manual and it has made no difference.
Is it done for or has anyone had a similar experience with this model? I'm assuming because of its age that parts might be difficult to locate and expensive.
Any replies appreciated - thanks.
