Denon AVR-2307 £379.99??
Discussion in 'AV Receivers & Amplifiers' started by ChristianBeccy, May 3, 2007.
Tags:
  1. ChristianBeccy
    ChristianBeccy
    Nov 20, 2006
    297
    +17
    http://www.leconcepts.com/rxr/Denon/denon2106.htm
    Aspects of this page suggest it's the 2106, although there are plenty of references to the 2307. I wonder if they are obliged to supply the 2307 at that price? If you 'Add to basket' it seems to add a 2106.
    :suicide:
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,577
    Edinburgh
    +1,269
    It looks like a misprint on the page. The page address and almost everything else there including the picctures would suggest it is the AVR2106. The correct link for the AVR2307 is here:
    http://www.leconcepts.com/rxr/Denon/denon2307.htm
    It is unlikely you will get them to supply you a 2307 for that price, most websites will have the phrase "Errors and Omissions Accepted" somewhere in their terms and conditions which allows them to decline to supply an advertised offer if a genuine error has been made.
    Even the bottom of that page has "Discontinued" scrolling right across it.
