Denon Avr 2105
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by marky1975, Dec 27, 2004.
  1. marky1975
    marky1975
    Dec 27, 2004
    65
    romford/essex
    Hi i have a denon avr 2105 works lovly
    but i have one prob
    i can get the on screen display when the tv or sky is on but when i watch a dvd OSD will not display does this ment to happen
    or is there a wrong wire up
    thanks very much
    mark
  2. SpudGunMan
    SpudGunMan
    i have the 1905 with the same results. only with svid/composite do i get the OSD. I woudl say its the way it works.
    it woudl be cool if you could choose to turn it on and off for all. You might be able to actually. I never read the manual but i know there is a OSD "mode 1 and mode 2" setting check that out. if no then just so you know its not just you.
