denon avr-2105 not staying on - help !
Discussion in 'AV Receivers & Amplifiers' started by Ianch, Aug 9, 2005.
Tags:
  1. Ianch
    Ianch
    Feb 19, 2005
    34
    when I switch my denon amp on the power on/standby switch goes from red to green then after 2 seconds reverts back to red ! I can't get any sound out of it because it won't stay on - any ideas !
  2. spl23
    spl23
    Jan 9, 2004
    2,671
    103
    +382
    Check the speaker terminals aren't short-circuited - you may have a stray strand of wire across them which is causing the protection circuits to cut in.
  3. Ianch
    Ianch
    Feb 19, 2005
    34
    have disconnected everything - still get the same thing - any other ideas or should I contact the HiFi shop I bought it from ?
  4. spl23
    spl23
    Jan 9, 2004
    2,671
    103
    +382
    In that case, I'm afraid it sounds as if a trip back to the dealer may be in order. The only other thing that might be tripping the protection circuits is if the amp is overheating, but assuming you haven't mounted it in an oven, that seems unlikely after 2 seconds ;-)
    Before you do, do look very carefully around the speaker terminals and make sure there aren't any stray strands of wire shorting something, even with all the cables disconnected - it wouldn't take any more than one single strand from within a speaker cable to have come adrift to cause a short that would shut the amp down, and that wouldn't be easy to spot.
