Denon AVR-1905
Discussion in 'AV Receivers & Amplifiers' started by bigfan, Dec 28, 2004.
Tags:
  1. bigfan
    bigfan
    Dec 28, 2004
    First post :)
    Here's my situation:
    I have a Sony 930 Stereo amp, which I've had for 4-5 years and am more than happy with. For stereo reproduction, it does the job extremely well.
    I have a pair of Celestion AVF 302 floorstanders, and a Mordaunt Short sub to back up the lower ends (these speakers lack the lower end).
    Anyway, yesterday, I came across a bargain in the sale - the two matching compact rear speakers and the centre to go with my front floorstanders. All I need now is something to process the digital signal from my DVD player. I knew about the Yamaha DSP-E800, and found myself in luck when I found it in a local Hifi store (albeit a pre-owned model).
    When I get the unit back home to plug it in, I found the pre-outs have a huge problem with hum. Nothing that I do will make the hum go away. This is obviously why the E800 was only £100!
    Due to the unavailability of the Yamaha DSP E-800 new and at a cheap price....I have begun to look at full receivers. The one that has caught my eye is the Denon 1905 receiver.
    If I get this, I plan to continue to use my Sony amp for CD purposes, while routing the processed signal from the Denon amp into my stereo amp, which will power the front two speakers. Basically, it will be set up as if the Denon is simply powering the rears and the centre.
    Firstly...is this a good idea generally? Is the Denon amp a good'un? Lastly, is the setup method described the right way of going about things? Is using the pre-outs for the front speakers best, or would I be better off powering the whole system from the Denon, and having some sort of switchbox for the speaker cable used in the front speakers?
    Cheers :)
  2. bigfan
    bigfan
    Dec 28, 2004
    Just to add another thing...as I'm using pre-outs....is the Denon 1905 a little bit overkill? Could I get away with a cheaper amp?
    I know the Marantz SR4400 is on offer all over the place at the moment, but I also have heard that it's movie sound isn't perhaps as good as some others.
  3. Kazman
    Kazman
    Jan 14, 2004
    5,269
    Luton, Bedfordshire
    +142
    I don't believe the SR4400 has the required preouts for what you require.
    Your original plan with the 1905 sounds a good'un, I'd stick with that mate :)
  4. bigfan
    bigfan
    Dec 28, 2004
    Cheers.
    Sounds like a plan :)
  5. bigfan
    bigfan
    Dec 28, 2004
    Sorry...another question.
    How much loss / interference can I expect by using the pre-outs? Will it be (for all intents and purposes) as good as a clean original source, say like the analogue outputs of the DVD player?
  6. Kazman
    Kazman
    Jan 14, 2004
    5,269
    Luton, Bedfordshire
    +142
    The difference won't really be noticeable as long as you use high quality interconnects. The amps in your Sony will still do the signal justice.
  7. bigfan
    bigfan
    Dec 28, 2004
    Thanks again. :cool:
  8. bob1
    bob1
    Nov 7, 2002
    4,328
    Sheffield
    +131
    I tried it once and couldn't tell any difference in sound using the pre-outs on the av amp ,i could notice a difference between the two amps though.
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    If you use good interconnects you should be fine :smashin:
  10. gavp
    gavp
    Dec 7, 2004
    274
    Preston
    +8
    New to this lark but some good advice always given so heres a conundrum for ya...
    Have a Sony STR-db1080 for processing and a Rotel RMB-1075 for power, recently bought a Rotel RC-1070 pre-amp to see the difference between it and the sony, wow! there is no comparison, I now have a problem as I use a DVD player only.
    How can I integrate this sytem so that I can use the Rotels as my Hi-Fi source and bring the Sony in on the act when watching DVD's without damaging/blowing anything up! At the moment I have V.D. Hul interconnects connecting DVD player to pre amp and aan Ixos co-ax also running from DVD to the sony....
    I understand that a Yamaha DSP-e800 will do this fine but for 5.1 will I be able to use the 1075 or use it to power the fronts and the sony to power the centre and rears!!!!!
    Any help would be much appreciated!
  11. Tejstar
    Tejstar
    Dec 4, 2002
    22,741
    London
    +1,075
    Welcome to the forums :thumbsup:
    I'm not sure about your conundrum but it may be worth opening a separate thread to get a better response?
