Denon AVR-1905 or Cambridge AZUR 540R
Discussion in 'AV Receivers & Amplifiers' started by brookesboy, Jun 6, 2005.
Tags:
  1. brookesboy
    brookesboy
    Jun 6, 2005
    44
    Hi guys - some advice would be appreciated. I've decided to invest in an entry level AV Amp and have so far narrowed it down to either the Denon AVR-1905 which I can get for about £220 or the Cambridge Azur 540R for £250. Could anyone give me some feedback as to which will best best for music and the general difference in performance between the tw0.
    Thanks.
    brookesboy
  2. psflynn
    psflynn
    Nov 10, 2003
    343
    Swindon
    +5
    funny that, i was about to post the same question! reviews so far have tended me towards the cambridge for its good performance with music also? is this a sensible deduction from the reviews?
  3. 5ergo
    5ergo
    Mar 7, 2005
    91
    9
    Id buy NAD.Reviews are saying that its better than Dennon or Cambridge.
  4. Dfour
    Dfour
    Jan 19, 2004
    4,021
    71
    Bracknell
    +86
    Isnt Nad hugely more expensive though. If you want musical amps you should also look at Marantz.
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    cambridge! music is fantastic!
