Timh
Has anyone got this Receiver yet? it has similer spec to the 2802 with less power, but its only £298 at unbeatable, could be a good budget amp, a Yamaha 630 eater maybe.
Quote from Denon
DTS-ES Discrete 6.1 and Dolby Pro Logic II with Power Amps for 6 Channels
The AVR-1803 is equipped with 6 amplifiers of equal power, one for each channel, in a discrete configuration for total accuracy when reproducing sound from demanding DTS-ES Discrete 6.1, Dolby Digital, DVD-Audio, and SACD sources. The Dolby Pro Logic II feature lets you hear 2-channel stereo sources in realistic 5.1-channel surround sound. For multi-room versatility, the AVR-1803's Multi Source function lets you enjoy audio, for instance, in one room while another program source is playing in the main room.
Quote from Denon
