Denon AVR-1708-B any good?
Discussion in 'AV Receivers & Amplifiers' started by simz, Jan 17, 2008.
Tags:
  1. simz
    simz
    Dec 4, 2006
    359
    19
    Newton Aycliffe County Durham
    Im looking to get a new amp, i've got my eye on the black Denon AVR-1708-B.
    Can anyone who has this tell me if they are any good?
    Also with this amp handle Dolby True HD ect from the PS3 and my Toshiba HD-E1 over HDMI?
  2. simz
    simz
    Dec 4, 2006
    359
    19
    Just being reading about and it seems that SONY STRDG910 might better suit my needs?
  3. rwniel
    rwniel
    Jan 20, 2007
    1,050
    63
    +232
    Both the Denon AVR-1708 and Sony STR-DG910 are good av receivers; I would suggest you get a demo (along with the Onkyo SR605). The STR-910 is a popular choice because it's the cheapest av receiver that will do LPCM sound over hdmi and is therefore a good match for the PS3 and HD-E1 ( - decoding of TrueHD is done by the player before being passed to the receiver through the single hdmi along with video). It also has 3 hdmi sockets unlike many receivers (which usually only have two). It'll also upscale component sources over hdmi which the AVR-1708 won't do, leading to simpler cabling between the av receiver and your television with non-hdmi sources.
    Robert
  4. ShadowTD
    ShadowTD
    Jan 22, 2007
    439
    28
    +50
    I'm currently considering the 1908 for one main reason: 7.1. My living room is quite long and fairly optimally designed for 7.1 placement, so I'd be a bit daft to ignore that. However, the Sony 910 (and I believe the Onkyo 605) are unable to apply Prologic IIx processing to a 5.1 pcm source to use all four rear speakers - they can only do 7.1 when fed 7.1. The 1908 can apply surround back processing to a 5.1 pcm input. It can also upscale to HDMI. However, it doesn't do TrueHD or DTS-MA onboard (not that I think those things are particularly neccessary).
    The Pioneer 1018 will do *all* of these things. I think I'll probably hang fire to see how it reviews before I actually put my hand in my pocket. My DSP-A5's lasted 7+ years and I fully intend to have its replacement for at least as long...
