Denon AVR 1306 stolen - what to move on too?
Discussion in 'AV Receivers & Amplifiers' started by Ironlegion, Jan 24, 2008.
Tags:
  1. Ironlegion
    Ironlegion
    Jan 31, 2006
    5
    first off Happy birthday AV Forums!
    I was hoping some one would be able to help me. Recently my Denon AVR 1306 receiver was stolen from my home :(, I now have to go about buying a new receiver. My budget is £200 and if at all possible would would like something thats an improvement over the 75watt per channel output of the 1306.
    Any ideas would be greatly appreciated.
  2. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
  3. hecmac
    hecmac
    Dec 25, 2007
    23
    hi,just bought the Denon 1907 avr,sounds great with my Tannoy SFX 5.1 speakers and in Richersounds it is priced at £170.I found the set up hard but now that it is up and running i just love it.
    sorry for your troubles
    hecmac
  4. Ironlegion
    Ironlegion
    Jan 31, 2006
    5
    Thanks guys.
    I guess a 7.1 system can handle a 5.1 set up then, as that was goingto be next question. I've been looking at the denon and it seems to be th way to go. Going to take a trip down to my local richer sounds some time soon and have a gander.
    Cheers for the help.
    Iron.
  5. sp_harris
    sp_harris
    Feb 13, 2006
    582
    +60
    Yes, you can tell the amp that you only have 5.1 speakers and it will ignore the surround backs. Some amps will also let you use the unused two back channels to bi-amp the front speakers (if your speakers support this).
  6. im333
    im333
    Mar 31, 2007
    80
    its £199 at RS - how £170?
