Denon AVCS1R PROBLEM
Discussion in 'AV Receivers & Amplifiers' started by Sicoe, Mar 23, 2006.
Tags:
  1. Sicoe
    Sicoe
    Dec 10, 2005
    2,012
    Kettering
    +40
    Hi All
    I was watching a dvd today (derailed to be exact) and all of a sudden the sound dissapeared, i checked the amp and the red light was flashing on and off quite fast and there was no writing in the middle.
    After a bit of investigation ive found out its happening on jumpy scenes or gun shots etc when the sound is at -15 or ABOVE if it is below that it handles fine and carrys on.
    this has never happened before and usually play film around -10 or lower sometimes for demo:thumbsup:
    Has anyone had this problem or can anyone recommend any help or where to begin.
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Does the amp have good ventilation, and what is the impedance of the speakers it is driving?
  3. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    Sounds like it's overheating and shutting down. It's worth having a quick check of speaker connections just in case there's any stray wires touching the casing at all.
  4. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Whats the sound level? Set down with an SPL if you have one and see what it reads, set the SPL to Slow and C waiting.
  5. Sicoe
    Sicoe
    Dec 10, 2005
    2,012
    Kettering
    +40
    Hi all
    Im not that techy so ill try my best but thanks for the answers
    i looked at the back of the amp and all cables seem fine
    its sitting in an arca cabinet with the centre speaker above it, it was pretty hot when this was happening so i switched it off and left it a good 4 or 5 hours so it cooled down and then 1 hour into a film it happended again.
    i used to have the se version the model below and this never gave a problem in the same position.
    the speakers im using are pmc fb1s and tb2 + as the centre and tb2s to the rear, with a couple of rel strata subs.
    does this give you enough info and what do you guys recommend next.
    Thanks again for all the info guys im really greatful:eek:
  6. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    Still sounds like overheating to me. Easiest way to check is just take it out of the cabinet for a movie (if possible) and see if it still shuts down.
  7. Sicoe
    Sicoe
    Dec 10, 2005
    2,012
    Kettering
    +40
    Thanks Jase
    i will try that later
    although it only does it on the certain parts and the same parts of the films i watched, so for example if i try it soon and go straight to that part where it cut off and it does it does that mean we can rule out that problem
    cheers
  8. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    If it did it straight away when the amp is cool, yes.
  9. Sicoe
    Sicoe
    Dec 10, 2005
    2,012
    Kettering
    +40
    Hi jase
    I tired it straight off from cold and it did the same, but i then put it in stereo and dropped it to -05 and it didnt do it which tells me its something to do with the suuround, ill do some more digging tonight.
    Cheers:thumbsup:
  10. Jase
    Jase
    Mar 16, 2001
    10,934
    United Kingdom
    +3,247
    Check your speaker drivers/tweeters as well.
  11. Sicoe
    Sicoe
    Dec 10, 2005
    2,012
    Kettering
    +40
    Hi All
    After a lot of investigating it was the ex 7.1 speakers that were causing the amp to cut out.
    reason was i had my projector sitting in the window cove with the ex speakers either side, the heat must of been causing the problem, ive moved them now and all seems to be ok.
    Thanks for all your help guys.
