Denon AVC10 SE and banana plugs?
Discussion in 'AV Receivers & Amplifiers' started by UrbanT, Jan 6, 2002.
Tags:
  1. UrbanT
    UrbanT
    Jan 6, 2002
    13,309
    Aldershot, Hants
    +3,038
    Can any fellow owners tell me whether you can use banana plugs in this amp? I have had a quick look at the back but because its so tightly packed in I can't see properly, and don't want to rip the whole lot out to find out.
    So far, I can see the holes are blocked and that it doesnt look like a bung at the end. Also, you cannot unscrew the screw fully so I couldnt take one off to have a look.
    In the review on the main site, the picture looks like there are no plugs in the holes so I'm a bit confused.
    Cheers for any help.
  2. Kevin Harris
    Kevin Harris
    Dec 16, 2001
    122
    16
    Glasgow
    I am sure you will be able to use Banana plugs.
    All I had to do with my DENON AVR3802 is use a stanley blade and lever the bungs out, they were pretty tight tho.
    Kev.
  3. UrbanT
    UrbanT
    Jan 6, 2002
    13,309
    Aldershot, Hants
    +3,038
    Thanks Kevin, but I would really like a definitive answer from an owner who knows for sure. Its because I don't want to buy them and then find I've wasted my cash :)
  4. Tim Ashdown
    Tim Ashdown
    Sep 20, 2000
    645
    28
    East Sussex
    +87
    Kevins right. Having owned the 10SE, you can use remove the bungs 100%. Unfortunately its an awkward job. I used a small flathead screwdriver to pry them out. I have also had the A1D and now the A1SE so its pretty much the whole Denon range that are able to do this.
  5. UrbanT
    UrbanT
    Jan 6, 2002
    13,309
    Aldershot, Hants
    +3,038
    Thanks for the help, will get my tool kit out I think :)
