Denon AVC X8500H Owner's thread
Discussion in 'AV Receivers & Amplifiers' started by petetherock, Feb 13, 2018.
Tags:
  1. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    The flagship that's supposed to rival the old Denons of yore..
    The official website:
    AVC-X8500H
    A video explaining the major bits:
    First preview of the DENON AVC X8500H Amplifier
    Start watching around 10:00 for the AVC 8500 information.
    27kg!
    Thick panels !
    Copper plates around the power section.
    Griffin Lite 32 bit DSP chips!
    32 bit up-conversion:
    ADSP-SC58x and ADSP-2158x Series | Analog Devices
    Around the 25:00, the video says it can consume 2800W to power all 13 channels ... [​IMG]
    Some important info from audioholics:
    Denon AVR-X8500H World's First 13.2CH AV Receiver Preview
    What does the AVR-X8500H Offer Over the AVR-X6400H?
    • 13 amp channels vs. 11, and 13.1ch processing vs 11.1ch max on the X6400H.
    • Higher power rating (150W vs 140W into 8ohms, 2CH driven).
    • Physically larger (about an inch taller, two inches deeper, and quite a bit heavier). The user manual states it weighs a whopping 51.4lbs despite the website error showing 39lbs. we confirmed with Denon at CES the correct weight is stated in the user manual.
    • 15.2ch RCA pre-outs vs. only 11.2 on the X6400H.
    • 15 pairs of speaker binding posts vs only 11 on the X6400H.
    • The above facilitates the ability to run BOTH a 13ch Auro3D setup and a 13ch (9.1.4 / 7.1.6) Atmos setup without having to ruin positioning for one or the other. Because there are FOUR pairs of height speaker outputs (pre-out and speaker posts), with flexible assignment (including being able to assign Height4 to Front Wide output) you can do a complete Auro3D setup with five heights + VOG and still have another pair of height outputs for Top Middle or Front Wide use with Atmos.
    • The X6400H, of course, can only do 7.1.4 (no wides) and is limited to 10.1ch Auro3D (5.1 + 4 heights + VOG). And the only way to practically mix Auro + Atmos is to use a Front Height + Rear Height layout. Plus the X6400H requires you to sacrifice the Sub2 output for VOG if you want to do 10.1ch Auro3D, whereas the X8500H has dedicated outputs for Center Height and Top Surround (VOG).
    • X8500H also has a "Custom" amp assign setting which allows you to map virtually any speaker binding post to any channel of output. For example, if you're using a 5ch amp to power LCR+Surrounds in the main zone, you can repurpose the unused FL/FR and SL/SR amps in the AVR to power Zone 2/3 speakers (the X6400H only has predefined templates for amp assign).
    • The X8500H also has a "pre-amp mode" which disconnects the amp section.
    • 7.1ch multi-ch analog audio inputs, extra (3 vs. 2) component video inputs.
    • Future HDMI 2.1 hardware upgrade to increase lifespan by supporting 8K resolution and more (the same way they offered the "A" upgrade to the 7200/8802 for HDMI 2.0 in the last generation).
    • The X8500H has different DAC's specified, it lists the AKM AK4490EQ for the X8500H and the AKM AK4458VN for the X6400H. A quick check shows 5dB increase in SNR for the DAC in the X8500H
    • The X8500H can do a vertical stretch for use with anamorphic lenses.
    • X8500H has a rear USB input in addition to the front USB, the rear port is rated to power devices so more practical for a streaming stick or cooling fan etc.
    • The X8500H has a nicer remote with "learning" capabilities to copy IR commands, macro capabilities, and also a "Remote ID" setting so you can prevent conflicts with other Denon device remotes accidentally changing it.
    • Like Like x 2
    • Thanks Thanks x 1
    • List
  2. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    Will do a review once I have this setup and run in... :)
    • Like Like x 4
    • Thanks Thanks x 1
    • List
  3. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    [​IMG]
  4. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    This baby weighs a ton! So take care when you move this..
  5. ivagiglie
    ivagiglie
    Jan 18, 2017
    25
    3
    Southern Germany
    +8
    Sweet! What speakers' setups are you planning to try/test?
    It should be available in Germany in ~10 days and I'll get it right away.
    Can't decide yet if I'll go for the front wides or 6 upfiring channels though...
    Looking forward to your review!
  6. gibbsy
    gibbsy
    May 17, 2007
    11,627
    3
    Cwm Cynon, De Cymru
    +6,149
    Damn that looks good. Totally, totally over the top for the rest of my kit, especially now as my fronts are driven by a Rega Elicit-R, but I so want one.
  7. kahlua
    kahlua
    Nov 16, 2014
    1,739
    116
    n.ireland
    +1,030
    epic piece of kit,congrats and keep the pics coming.:eek:
  8. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    You can see my current setup in my signature.. I use the Dynaudio Confidence series. These are 4 ohm designs which should give them a real workout :)
  9. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    More on the goodness inside:
    "Denon AVC-X8500H Amazon Alexa
    The manufacturer also introduces a new design for the X-Series with the Denon AVC-X8500H. The amp case features a solid aluminum front panel, a reinforced topcover, two separate side panels, and a two-line display that comes from Denon's NE stereo series. The interior is dominated by a centrally arranged, voluminous transformer in addition to the 13 output stages, which are arranged in monobloc construction right and left of the toroidal transformer.
    Denon will also release the eARC (Enhanced Audio Return Channel) via a future free firmware update. This allows HD and object-based audio (Dolby True HD / Atmos / DTS-HD / DTS: X) to be transmitted via an HDMI connection to the compatible TV or TV apps.
    Another update (expected from early summer 2018 in Germany / Austria) should also unlock the voice control Amazon Alexa."
    Denon AVC-X8500H connectors
    Vinyl enthusiasts can look forward to a phono input, while digital players will find their way to eight HDMI inputs with full HDCP 2.2 support.
    Three HDMI outputs allow the parallel use of a TV and projector in the main room and the additional use of another HDMI output for a second zone.
    The digital feature set is made possible by a fully redesigned DDSC HD-32 digital section, which features two brand new 32-bit dual-core processors from Analog Devices. A total of eight 32-bit stereo converters are responsible for converting the digital signals.
  10. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    Hmm
    I can't find absolute proof yet but it seems that the 8500 only has 44000uf of capacitance.. that's the same as the 7200 and 8012 ...
  11. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    Surprising, if that's the case. The older 10Ch AVC-A1XV(A) had 132000uf.
  12. KelvinS1965
    KelvinS1965
    Jan 3, 2006
    16,841
    +7,538
    To be fair there is only so much they can cram into a single box no matter how heavy it is.
    I wonder whether manufacturers would be better off making a sort of hybrid receiver/processor with a separate power amp option: Maybe put some lower powered amps in the same case to cover height channels and have an extra box for the main channels. Make it configurable so that it could be used for basic 5.1 use on it's own while you save up for the power amp.
  13. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    Every slide I have seen shows two 22000 caps. Unless it's just an illustration, it's a bit disappointing. It can be an industrial decision since you use off the shelf parts that are shared amongst a few models.
    The same caps are used in the marantz pm11s3. And that toroidal could be the same one used in the 8012.
    Three of them makes it uneven but to have four giving 88000uf is a tad hopeful...
  14. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
  15. badman
    badman
    Nov 21, 2016
    43
    22
    Lincolnshire
    +28
    Awaiting the review!
  16. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    I made a little table of the differences between the 8012 and the 8500:
    There are probably more, but I hope this helps those who are consider the two models ..
    [​IMG]
  17. ailean
    ailean
    Jan 17, 2006
    583
    43
    +152
    There's been some good hands-on discussion on the 'other' forum regarding actually working speaker and decoder combos. It is shiny but I'm thinking maybe waiting for the A version rather then the pain for sending back for the upgrade.
  18. vn800art
    vn800art
    Dec 30, 2016
    77
    Pescara, It
    +11
    OP is enjoying his new toy ...
    Please tell us Your valuable opinions about Auro3D and the configuration You settled on!
    I'm actually using Auromatic at 10.1 with Sr7011
    Regards
    Alessandro
  19. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    Been traveling a far bit, and letting the unit run in, no issues pushing my 4 ohm Dynaudio Confidence speakers, so I hope to share some initial impression soon :)
  20. JH4
    JH4
    May 6, 2003
    2,443
    83
    +286
    I have commented on this before, but why have they kept the obsolete component I/P's, but deleted the digital audio O/P's. That's my only gripe with this new Amp.
  21. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    I don't think digital outputs will be allowed given the current piracy climate..
  22. ailean
    ailean
    Jan 17, 2006
    583
    43
    +152
    There is the extra HDMI out, I'm sure there are a few boxes on the market that could convert that to opt out (compatible formats at least). ;)
  23. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    A few quick points:
    - setup is about the same speed or just a tad faster (new chips?)
    (I will use the new Audyssey app once I have done some basic listening)
    - it has the typical Denon house sound, which is somewhere between a Marantz (warm) and the hotter/brighter Yamaha, or the shiny bright Onkyo/Pioneer sounds, YMMV
    - balls to drive most domestic speakers that aren't top shelf audiophile mad ones
    (it drives my Dynaudio Confidence speakers fine)
    - if you are looking for a 7200WA with more speaker options, then you have some to the right place
    But if you want super stereo, quantum leaps over the older flagship, then you may be disappointed
    The issue is that I also own the Marantz PM 11 S3, which definitely sounds better when you sit down and listen in stereo mode. The grip is better and even though it's 'only' 100W, it uses the same size caps and likely the same transformer as the 8012, so it's no puny amp.
    Will write down my in depth review soon...
  24. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    The build of this amp is really much better than the average AV amplifier. The chassis, the footers and even the trap door have receieved a lot of care.
    Despite only using the same caps as in the 7200, the transformer is much heavier and this bodes well for the power supply.
    Pete's Write: Denon AVC X8500H review
    Pros:
    13 channels usable at once
    Big transformer that can power 13 channels
    Well built - best of all the big brand HT amps right now
    Does all three flavors: Auro, Atmos and DTS X
    Cons:
    Expensive
    Not a big improvement if any over the older 7200 for audio
    You need to pay for the HDMI 2.1 board upgrade
  25. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    I don't have my Rotel 1580 anymore, but that would be my benchmark for a solid AV amp with powerful internal amplifiers. The Denon performs around the same level.
    For music and resolution, my SR 7010 takes some beating and I would say the Denon has a different sound. But in HT, unless you double your budget AND hire someone to do the calibrations, live in an ideal HT room, AND place every speaker in the most ideal position, the Denon is quite simply the go to amp for the year and possibly to date.
    If you own the 7200, there's no need to lose sleep, and if you own the Marantz AV 8802 or the like, it is glorious in HT I am sure, but the extra money probably goes towards music and it will cost you.
  26. badman
    badman
    Nov 21, 2016
    43
    22
    Lincolnshire
    +28
    My AVC x8500 will be delivered today.
    I will be an official owner from today.
    Im quite excited.
    Anyone else on here getting one?
  27. kahlua
    kahlua
    Nov 16, 2014
    1,739
    116
    n.ireland
    +1,030
    plenty of pics,:)
  28. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
    I spent some time scrutinising the chassis of the Denon, comparing it to my older Marantz SR 7010, and the 7200, and it is really well made.. the metal work is significantly more solid, and the insides are well designed, and I still can't believe they only put a pair of 22 000uF caps inside. The caps look pretty big, and are located right behind the transformer.
    I can see this amp lasting for a while.
    Oh, a bit of trivia, this amp was made in Fukushima, so I wonder if anyone has taken a Geiger counter to it?
    • Like Like x 2
    • Agree Agree x 1
    • List
  29. petetherock
    petetherock
    Jun 7, 2006
    1,169
    2
    +333
  30. badman
    badman
    Nov 21, 2016
    43
    22
    Lincolnshire
    +28
    Well it' just arrived but it won't be installed till next week.
    Initial thoughts
    Very well made. High quality materials.
    Looking forward to setting it up.
