Hi. Been a while. But alway been reading this forums which help me, guilde me getting new tv and home cinema packages over last two years. Which was very helpful.
Anyway I seem to have problems getting the multeq app to connect with the mics and/or going through calibration stage which not really responding.
The problem is everytime I ask to plug the mic in - the next button either won't come available or just take forever to light up the next button once mic plug in. And when it does, its seem to go on and on while it should be checking subwoofer level.
I remember it gave me the problem before and I believe I got it working by changing something on the router which I forgot what was it. I try on and off with different setting. And no luck.
Last time I did it was before Xmas and I gave up. And connect to old backup bt router temporarily go I can go through the calibration process. But this time I like to get this working.
So I do believe it something to do the asus router. I sure i got it working by turn something on or off. I think it went back to default mode after I done firmware update last year. Now I cant remember what I did to get it working. And why bt router work fine but not the asus?
Have anyone have similar problems?
