Denon AVC-A1SR online review (German)
Discussion in 'AV Receivers & Amplifiers' started by Reiner, May 10, 2002.
Tags:
  1. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
  3. Ian J
    Ian J
    Aug 6, 2001
    25,630
    +4,906
    The translation is so interesting that I have reproduced the first paragraph below:-
    It is not simple to make outstanding equipment still better - however the time does not stop particularly in the schnelllebigen home cinema business, and so the tooth of the time gnawed at the monumental Denon Topliner Avc-aße . While for those customers, who already possess a Denon Avc-aße, for 899 EUR a aufwaendiges Upgrade stands ready, the successor Avc-aßr, as usual with Denon alternatively in black or golden execution available, is starting from May for 4699 EUR available. Just like the Avc-sße with Upgrade the Avc-aßr has a THX Ultra II certificate. THX Ultra II bring along 2 programs, "Cinema" and "Music". While the Ultra II Cinema mode DTS and Dolby digital 5,1 sound of film is to optimize 7,1 in as perfect a way as possible on the rendition on a loudspeaker system, the Music mode creates in the back two virtual direct emitters. How this goes, read further down in the detailed THX Ultra II description. The moreover also the Avc-aßr DTS 96/24, a quite interesting new clay/tone format, decodes which convinces by good sound quality, particularly by a pronounced spatialness. Unfortunately the offer at software is still strongly reduced. Further highlight with the Avc-aßr is DENON left, a new digital connection for equipment cross-linking among themselves via RJ-45-Stecker. DENON left is 3 x as fast as IEEE1394 FireWire, the maximum data transfer rate betraegt1,2 Gbps owing to LVDS (Low volume days differential transmission). Thus DENON is left suitable for the digital transmission of 192 kHz/24-Bit-2-Kanal as well as for 96 kHz/24-Bit -6-Kanal - thus a full compatibility is ensured to DVD audio. Also the possibility exists of making the AVC A1SR internal bass management and the run time adjustment accessible also when playing DVD audio or SACD Discs. The transmission of the signals is made by shielded "Twisted Pair" cable (STP). Denon provides also for the suitable Zuspieler: The new High end to DVD Player Denon Dvd-a1, that shortly with us to the test start. Then there are Denon also more to the topic left in practice. Already from many other Denon models admits: The adjustable Subwoofer Uebernahmefrequenz. Alternatively 40/60/80/100/120 cycles per second are adjustable. Who does not use THX certified loudspeakers, with which the Subwoofer Uebernahmefrequenz is given in accordance with the THX Ultra standard with 80 cycles per second (OS your position for assumption frequency: "Fixed THX"), will be pleased about the variable assumption frequency. Who uses high-quality condition loudspeakers, the assumption frequency can quite to 40 or 60 cycles per second to adjust, which has the audible advantage in practice that the active Subwoofer is not to be located no more in the hearing area, because it really transfers excluding frequencies from a such depth, which cannot locate the human hearing any longer.
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,620
    United Kingdom
    +2,221
    Are´nt translation programs great??:D :p :D
  5. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    They're especially great when they only translate a fraction of the page like that one does (on my computer anyway). I can't translate the bottom half! :(
  6. Guest
    It must be worth buying just for the adjustable Subwoofer Uebernahmefrequenz
  7. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,620
    United Kingdom
    +2,221
    Does the same on mine!:rolleyes: Annoying isnt it?
  8. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Most translations are limited, so copy and past each paragraph one by one.
    You can use e.g. www.babelfish.com for that.
