Denon AVC A1SE + Velodyne Subwoofer
Discussion in 'Subwoofers' started by MoonsSpawn, Mar 21, 2002.
  1. MoonsSpawn
    MoonsSpawn
    I have a Denon AVC A1SE amplifier and I've just bought a new Velodyne SPL-800 Subwoofer, which has two Line level Inputs - left and right.
    My question is this: How do I connect this to the A1SE? As far as I can make it out, the Denon amp only has provision for a single line level phono input marked 'SW' on the pre-out back pannel. So, erm, where does the other phono plug go?
    Any help would be very appreciated,
    Steve.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Either connect it to the input labelled "mono" at the subwoofer or if there is none use the L(eft) input. Or use a Y-cable to split the output from the amp.
