Denon AVC-A1SE Setup Question
Discussion in 'AV Receivers & Amplifiers' started by Ballistix, Feb 5, 2003.
Tags:
  1. Ballistix
    Ballistix
    Hi fellas,
    OK, finally fine tuning this beast. Got a question...
    I've setup all the channels to 75DBs using my sound meter. However, it's clear that I need to have a higher sub/LFE output on DVD-Audio discs than I do for my DVD DTS/THX etc setup.
    Now, I've setup the channels in the global settings...but I have heard that I can also set channel settings for the DTS, THX DVD on its own . I know that this will set the same for all of the DTS and THX outputs, but I want to differentiate the sub LFE level between EXT IN and the Digital in.
    Anyone know how I do this please?
    Hope you can help!!
    Regards,
    Tony
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,284
    United Kingdom
    +1,566
    Hi Tony
    You can have seperate settings for THX or for Dolby Digital/DTS.
    To adjust the SW level of the EXT-IN, press the Mode Select button on the front panel until the Channel Levels appear, you´ll then be able to adjust these using the knob on the right. Alternatively you may have to use the channel level adjustments of your DVD Audio player, if it has them.
