Denon AVC A1SE flap won't stay closed !
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by JH4, Feb 12, 2005.
  1. JH4
    JH4
    May 6, 2003
    2,474
    83
    +304
    Apologies for this minor problem query, but the front flap on my Denon A1SE won't stay closed ( ie. up ) any more. Nothing seems obviously broken, but I can't see how it works, and I'm reluctant to take the whole thing apart because of all the de-connecting of cables involved. Does anyone out there know how it stays in the closed position ?
    Many thanks in advance.
  2. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Have you tried blue tac?
    If it's just a cosmetic thing then that wil solve it.
    Or you could try one of those door magnets, like on kitchen cabnets, i think you can get them with a sicky back.
  3. JH4
    JH4
    May 6, 2003
    2,474
    83
    +304
    Yeh Thanks for that. I've since discovered that you can pull off the 'drawbridge'. The left hand side has a toothed cog which should locate with a friction wheel inside the box, but does'nt appear to do so. Nothing looks broken, but I've fixed it with a magnet from Homebase, which does the trick !
  4. pragmatic
    pragmatic
    Nov 9, 2004
    12,156
    +1,647
    Simple ones are always the best, although its a shame you can't get it to work 'properly' but i suppose there will be no differecen in practice between the orional and new solution.
