Denon AVC-A1D Upgrade For THX6.1EX
Discussion in 'AV Receivers & Amplifiers' started by Phil, Jun 24, 2001.
Tags:
  1. Phil
    Phil
    Can anyone advise the most cost efficient method to upgrade the Denon AVC-A1D For THX6.1EX capability ?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    IMHO there is no such option ... ?
  3. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    Well, to clarify there is no DD 6.1 EX sound format as the rear/back channel is not discrete. Only DTS 6.1 ES provides this.
    The only way to upgrade to 5.1 EX is to add an external device such as the CS-3X to the rear surround pre amp outputs. The signal for the side surrounds could then be put back in to the A1D. You would of course need an external 2 ch power amp to connect the CS-3X to the back surround speakers.
