Denon AVC A1D/REL Q200E Problem
Discussion in 'AV Receivers & Amplifiers' started by RobsterD, Mar 20, 2002.
Tags:
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    I'm running the Rel off the 'sub out' from the Denon and whenever I change the input on the Denon I get feedback in a way of a thud on the sub,it only happens on the LFE input on the REL,I dont remember this occuring before and I've checked all settings which all seem to be correct,the phono lead has also been checked and is fine,any thoughts on this annoying problem would be appreciated
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,714
