Denon AVC-A1D or Denon 3802?
Discussion in 'AV Receivers & Amplifiers' started by dAvE6, Jun 2, 2002.
  1. dAvE6
    I've just sold my sony db1070 amp as i'm unhappy with it. I had pretty much decided on the Denon 3802, before i saw the review of the AVC-A1D.
    But i'm confused. It's quite old now, so is it a bad idea to locate one 2 and a half years after it was released?
    How does it compare to the 3802 in terms of sound/features?
    Overkill for my b&w 603/601 speakers?
    Is it not an ordinary amp? It appears to be a power amp, which i know nothing about. And, anyone know places which sell it at a bargain price?
    Any other advice or suggestions welcome.
    Thanks very much.
  2. Guest
    The A1D was £2,000 worth of amp in it's day and he was often crowned The King bar none. It was replaced by the A1SE and since then the A1/11SR (all still around £2k - £3k). These have added a redesigned rear panel, more digital ins and outs (as if eight wasn't enough !), an extra component video input, a bit more power (170W p.ch.), ES/EX capability, a video circuitry 'off' switch, 'AL24 Processing Plus' and more besides - though not all of these are on all of 'em and weren't added in that order, IYSWIM.
    Alternatively, the cheaper AVC-A10SE is superb if you can find one but it lacks AL24 processing (?) and analog devices OP-275 op amps and probably has less ultimate audio quality in comparison - but only if we're being picky. Whilst it does have ES/EX decoding and assignable power amps, an extra offboard power amp is required for 6/7 channel work such as the dedicated POA-T10. The 10SE lacks the front-panel drop-down flap and has slightly less Watts per channel too (an A1D has 5 x 140W).
    Remember that the lesser 'AVR-' Denons (up to and including the 3802) are all non-THX but they do have tuners aboard - which the high-end models lack. There are some raving in-depth reviews of the A1D to be found online - as well as those by users on Audioreview.com (every one giving five stars). Which review were you referring to ?
    As for comparing Denons for specs, you can get the relevant specsheets via pdf from Denon. They all have similar formatting so it's easy enough to compare models.
    A top-end amp is not going to be overkill for any good pair of speakers. I've no doubt that your B&Ws will be up for it.
    Hope that helps.
    Anyway, my underlying reason for answering in this thread is that I've got an AVC-A1D (absolutely mint with box, remote and manual) which I would consider selling (it's less than six months old and has 18mths warranty remaining). So you certainly got lucky in finding one some two-and-a-half years after it's initial release but it's still going to cost around £750 inc. to prise this 22KG monster off me.
    BTW, I'm selling as a downgrade in order to buy a cheap car.
    Let me know if you might be interested.
  3. Reiner
    Jul 16, 2000
    If you are into the latest features and decoding of new surround sound formats but think the AVC-A1SR is too expensive you may wanna consider a 2nd hand AVC-A1SE + Upgrade. That should work out cheaper and give you most up-to-date features except a very few minor ones which the AVC-A1SR will have - but at a higher cost.
