Denon AVC A11SR
Discussion in 'AV Receivers & Amplifiers' started by SCAMP, Jan 26, 2003.
Tags:
  1. SCAMP
    SCAMP
    Dec 2, 2002
    35
    I have recently updated my Home Cinema package with the Denon A11SR Amp. It seems that the speaker connections at the back of the amp are Bindng posts only and will not accept Bannana plugs. Could somebody please confirm this-Thanks
    Scamp
  2. BabylonP
    BabylonP
    Dec 10, 2002
    98
    11
    +5
    If you look very closely you should find that there is a small black plastic plug that is pushed into the centre of the hole. This can be removed gving you access for bannana plugs.
    If they are like mine, they needed a bit of encouragement.
    Phil
  3. lespaton
    lespaton
    The end of the binding post is shrouded for "safety" reasons (EC ruling apparently). I believe you can break the covering with the tip of a ball pen. Do a search on this and the uk.media.home-cinema forums for more info. Either that or there is a small insert that needs to be removed. This varies with the particular maker.
  4. magking
    magking
    Jan 6, 2001
    378
    Norway
    I can confirm that it accepts banana plugs.
    I have the AVC A11SR myself and all you need to do is use a sharp object to remove the plastic safety plugs as mentioned earlier.
  5. SCAMP
    SCAMP
    Dec 2, 2002
    35
    Thanks for the responses.
    I have used a sharp implement and they removed fine.
    I am wiring it up to a Pany 5 plasma, Denon 3800 dvd and
    JM Labs Cobalt speakers. Cables supplied by Chord.
    Only thing o/s is A/V stand to hold amp/cvd and centre speaker, I am still comming to terms with cost of furniture-must be a good alternative!
  6. John-D
    John-D
    I have an AVC-A11SR amp and my speaker connections have no covers for the holes that take the banana plugs.
    Do you think this was/is a factory mistake?
    John
    PS. Glad to see it accepts banana plugs, though!
    Does anyone know where to get good quality ones from?
  7. John-D
    John-D
    Sorry, but can you get the on-screen menu on the amp to work with the component video output?
    Cheers again,
    John
  8. magking
    magking
    Jan 6, 2001
    378
    Norway
    No.
    The OSD is only on S-video and Composite video.
    This to keep the Component signal clean for optimum video quality.
  9. SCAMP
    SCAMP
    Dec 2, 2002
    35
    Did not realise about the OSD issue. Thanks
    I do not intend using the component on amp but rather go direct from DVD to Plasma for fear of reducing signal quality.
    Any issues here?
  10. magking
    magking
    Jan 6, 2001
    378
    Norway
    I have connected my DVD player direct to my PJ, and would recommend you to do that to.
    But i don't think the signal would be redused so much that you would see it if you connect through the amp. But if you don't have more component sources, why go through the amp?
