Denon AVC-A11SR as pre-amp; what is its equivalent standalone product?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by tjobbins, Aug 11, 2005.
  1. tjobbins
    tjobbins
    Jan 1, 2005
    162
    16
    Harpenden
    Hi guys,
    I currently have a Denon integrated AVC-A11SR which I use for both pre and power amp duties. However I am beginning to move to separate power amps on some channels.
    I am also wondering about the pre-amp stage; I am happy with the Denon at the moment, but would like to get an idea as to where it stands against standalone pre-amps.
    For example, how does it compare against a Rotel 1066 or 1068?
    I'm just trying to get an idea as to the relative strenghts of the Denon pre-amp, so if I spy any bargains on ebay I will know whether to go for them, and also so I know whether to spend 100% of my future budget on separate amps first, or whether, after I've got separate amps for my front channels, whether a different pre-amp would then be the correct step
    Thanks!
    Tom
