Denon AVC-A10SE source issue
MAP
Hi I have a Denon set up with an AVC-A10 SE and a DVD-5000. Also Laser disc player and VCR attached.
With the DVD player the video is screened using the DVD source but the sound is coming through on the Phono source. All other sources have the video and audio working together fine. Any bright ideas? Thanks
Jase
Is anything actually connected to the Phono Input? If not then somethings either not assigned correctly and/or the Video Select button has been pressed and another Input has been selected.
If you press the Video Select button on the front panel it should ideally say Source. It's designed so you can watch one video source whilst listening to the audio of another so check that it's not set incorrectly.
MAP
Thank you. Will try this.
