Denon AVC-A10SE Due for replacement ?
Discussion in 'AV Receivers & Amplifiers' started by Russ, Apr 19, 2001.
Tags:
  1. Russ
    Russ
    Aug 3, 2000
    214
    Warwick, UK
    +16
    The Denon AVC-A10SE is coming up for a year old now and is a bit of a missmatch in the range - compared with the newly updated 3801 (even though the A10 is a slightly different beast).
    Anybody got an idea/info when the replacement will be available ?
    Russ
  2. Matty N
    Matty N
    Rumour has it that a new product will be introduced to bridge the gap between the A1 and the 3801, and it is likely it will be Dolby ProLogic II endowed - as such it will probably be a couple of months before it is released (Denon is still fine tuning the software for DPL II alledgedly)
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Yes, I also believe that it will be THX certified, I've no idea which one but I suspect it will be THX Select.
    Mark
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Give Roger Bachelor, Denon's rep, a ring on 01753 888447, he should be able to give you more info.
    His pic is in the latest issue, the guy at the awards with the goatee.
    Rick
