Denon AVC-10SE question
Discussion in 'AV Receivers & Amplifiers' started by dick220369, Aug 12, 2004.
Tags:
  1. dick220369
    dick220369
    ive just came into the possession of a denon avc-10se amp and was wandering if it has a fan on the back. there seems to be a grill on the back where a fan should be.
    if it does have a fan then does it only come on when the amp gets to a certain temp, or should it be on all the time the amp is powered up?
  2. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,276
    Berks, England
    +131
    Apparently it's a two speed temperature sensitive fan. I've never heard mine running, although I guess you wouldn't if the amp is playing loud!
    regards,
    Rob.
  3. stevefish69
    stevefish69
    Jun 25, 2004
    4,184
    +439
    I believe that there are 2 fans which fitted to the Amp chamber from front to back. There are also 4 modes which use a combination of None/front/Back/Both depending on the heat level.
    If you pump out something that gives it a good workout (Robbie's Knebworth concert) seems to get them all going at around -10. The rear fan should well and truly come to life, and it feels like a hairdryer on full pelt.
    Hope this helps
