Denon AV3802
Discussion in 'AV Receivers & Amplifiers' started by danzor, Feb 14, 2003.
Tags:
  1. danzor
    danzor
    My amp (Denon 3802) keeps cutting out (even with nothing connected) and then works fine for weeks and weeks. I can't help thinking something inside is loose, the amp is not overheating and there are no dodgy connections any suggestions
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,370
    United Kingdom
    +1,733
    If its still under guarantee then take it back to where you bought it from, if its faulty they should replace it.
