Denon AV-A10SE & 4 ohm speakers
Discussion in 'AV Receivers & Amplifiers' started by Mark Ward, Mar 15, 2002.
Tags:
  1. Mark Ward
    Mark Ward
    Sep 12, 2001
    1,815
    41
    Kent
    +18
    My Denon AV-A10SE and & POA-T10 Power Amp both specify that the speakers should be between 6-16 ohms. The amp isn't switchable for different ratings.
    The Kef speakers I'm looking at are 4 ohms. What implications could this have? I Bi-Amp at the moment, would this cause any difficulties?
    Cheers,
    Mark.
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    DENON and THX test and certify down to below 4ohms, they just don't print it.
    Mark
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Unless you operate a Disco during the weekend I don't see a problem, every modern not-too-cheap AV amp/receiver should be able to handle a 4 Ohm load. Even then there should be some protection (thermal or load). No prob with your gear I assume.
    If you bi-amp I would worry even less as you have distributed the load to different amps already.
    However also the speakers sensitivity (measure in dB) may make a difference, the higher, the better. Around the 90dB mark is pretty good (+/- 3dB).
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,463
    United Kingdom
    +1,921
    The Denon will run the speakers no problem at all.
    As MarkB says, THX amps will run speakers down to 4 ohms (and below)
    cheers
