Denon av-3802 set up problems
Discussion in 'AV Receivers & Amplifiers' started by Labrea, May 21, 2005.
Tags:
  1. Labrea
    Labrea
    Im hopeing someone here has some info on setting up a Denon av-3802 as im having problems,
    I wired everything up as per instructions but when i press the system setup button on the remote nothing happens and i cant get the setup menu to appear on the tv.
    If anyone has encountered this problem or has any information on how to rectify this problem it would be greatly appreciated.
    Thanks in advance.
    :lease:
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,437
    United Kingdom
    +1,820
    Have you set the remote to AMP? It should say this in it's little display.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    The 3802 will only output the OSD via composite & S-Video. If you only have a component connection to your screen then you wont get the OSD, so just connect a cheap RCA to RCA lead for setup.
    Mark.
  4. Labrea
    Labrea
    Thanks for the info,
    I was trying to conect via another componet so just need to get the right cable and that should do the trick.
    Thanks again.
