Denon AV-2600 Quick Question
Dinglebert
My setup was working just fine. No issues but over the past week something has changed and I can't work out why.
Set up is simple enough. I have only two sources going into the amp. My UHD player and Sky Q box. The output from amp is into eArc on my Samsung. My issue is when I want to watch any of the apps on the Samsung. ie Netflix, Prime or Disney+. The sound is staying on the Sky channel and not changing and for the life of me I can't work out why. It will jump over if I switch off receiver and back on but thats just seems wrong.
It was jumping over itself until a couple of weeks ago. The amp is also from time to time switching itself off. I have double checked speaker cables and they are all OK. Its an open shelf setup which wasn't causing issues for past two months. To my memory I haven't changed anything in the setup for this to happen.
dante01
Ensure that ARC is turned ON within the AV receiver's HDMI configurations as well as setting the TV AUDIO SWITCHING setting to ON.. Ensure that the TV's implimention of HDMI CEC is engaged. THis it termed Anynet+ by Samsung. Ensure that the TV's speaker and audio output are set to the option associated with ARC as opposed to being set to the TV's own speakers. Once all these options are configured correctly then put both the TV and the AV receiver into standby and themn power them back up to establish a new HDMI handshakwbetween them that acknoeledges the new configurations.
Dinglebert
Cheers. All was set as you described. However I did notice that the tv audio switch was at off instead of on. Now working
dante01
Yeah, it sometines doesn't harm to check the basics such as the congurations. Anyway, glad that you resolved the issue you were having.
Dinglebert
The one thing which does throw me is when did it go to the off position. I didn't do it and no-one else in the houses understands how to switch the thing on!
dante01
Has there been a recent firmware revision and is the TV set to automatically update itself?
Dinglebert
No both are up to date.
I am having a real problem with eARC. Now at times when I fast forward a Sky program the sound is swtiching off. If I change TV to say Netflix it starts working again and still works when I put it back to Sky.
Dinglebert
Update. I have spoken to both Sky and Denon over past few days. The sound dropping out on changing channel issue is a Denon problem which they are working on. Easiest way to solve it is switch the box off and back on. Firmware expected mid-November.
