Denon Amp Question
Discussion in 'AV Receivers & Amplifiers' started by bobbles, Jun 29, 2004.
Tags:
  1. bobbles
    bobbles
    Quick question, does anyone know if the headphones are plugged into the socket on front of the amp will it mute the sound on the speakers?
    I have not got a full size jack to test it.
    If it does is it possible to output the sound from any device into the amp to headphones without muting the speaker sound?
    I have a Denon 1604 and Phillips wireless headphones.
  2. cwoj
    cwoj
    yep :smile:
  3. bobbles
    bobbles
    ok
    basically what i want to do is connect my wireless headphones to the amp to work independently of the amp
    I can output the sound from any AV device connected to my plasma, but the plamsa has to be on. Ideally I would like to do the same with the amp, is it possible?
