Denon Aktis Remote Upgrade - New version
Discussion in 'AV Receivers & Amplifiers' started by Matty N, Jul 16, 2001.
Tags:
  1. Matty N
    Matty N
    AVC-A1SE / AVC-5800 users that own an Aktis remote control.
    There is a new software update available at:
    http://www.dufflers.nu/denon/x/rc8000/index.html
    It is a 2.8Mb download that will require the use a USB capable (I think it was an A-B connector but can't recall).
    Give us a shout if there are any probs.
    BUT.... several users are reporting the old 'lock-up' bug that was evident in the original supplied version. The unit locks up while trying to update and doesn't work again. Seems a case of try your luck and see what happens. Either that, or you pronto users copy all the codes onto that and give it a go for everyone else!!
    If the unit does lock up, there is little you can do. You can try removing the batteries for some time and this has been reported to work on occasion.
    I can't manage to contact Denon as yet regarding support for replacement of then defective units.
    Matt
